Minneapolis Moline Tractors Discussion Forum
Need front rims for GB
Texas Red1
05-27-2006 08:32:44
I need some help. I need to get some wheels on the MM GB so i can load it. Are the front rems on a UTS the same as a GB. If the bolt pattern is the same i can use the ones on my uts to get it loaded. thanks for the help TR
LW
05-27-2006 19:18:08
 Re: Need front rims for GB in reply to Texas Red1, 05-27-2006 08:32:44
A GB is the standard large 6 bolt ag wheel There are lots of tractors and equipment that uses that wheel shouldn't be a problem to pick some up somewhere
Texas Red1
05-28-2006 07:27:29
 Re: Need front rims for GB in reply to LW, 05-27-2006 19:18:08
Thank you for the reply, Is that the 4 5/8 hole with the 6 inch bolt pattern?? I have 4 sets of hubs and all are different . the numbers are:
My UTS has # 33272R the others are:33522, 33106R, 33131R Does any of these numbers got to a GB? they are all 4 5/8 hole with 6 inch bolt pattern. Thanks fot the help. TR
LW
05-29-2006 15:38:57
 Re: Need front rims for GB in reply to Texas Red1, 05-28-2006 07:27:29
The G series takes the wheel with 4 5/8 hole and 6 lugs on s 6" bolt circle.
Texas Red1
05-29-2006 16:07:35
 Re: Need front rims for GB in reply to LW, 05-29-2006 15:38:57
Thanks for the help. right now it is about 30 miles from where i live and the two front tires and wheels are missing and the two rears are shreaded. it will be a lot easer to load it i can get some rubber on it. thanks again TR
glr62
05-27-2006 12:47:10
You will have to change the hubs.
