Minneapolis Moline Tractors Discussion Forum
Minneapolis Moline U Governor
Scott R. Kling
07-21-2003 11:11:18
I have a 1949 MM UTS, with the stock motor. When I run the motor, the governor wanders and the motor increases speed. If I put a weight on the governor linkage to the Carb, it functions normally. I have tried adjusting the governor and nothing seems to help. Is this governor wore out? What are your suggestions? Thanks.
Bob M
07-22-2003 15:03:06
 Re: Minneapolis Moline U Governor in reply to Scott R. Kling, 07-21-2003 11:11:18
Scott - Do you have the light spring in place between the throttle arm and the choke lever bracket on the carburetor? (Punch below for photo - the spring is just ahead of the governor to carb linkage).
When I rebuilt and reinstalled the carburetor on my '48 UTU I forgot to reinstall that spring. The governor was erratic and wouldn't idle the motor down all the way. Problem cleared up soon as I put the spring back on.
Kelvin
07-22-2003 18:33:30
 Re: Re: Minneapolis Moline U Governor in reply to Bob M, 07-22-2003 15:03:06
A MM governor is not supposed to need that spring. Your governor is worn some, needs shorter rod to work properly. Internal parts can't pull the throttle all the way shut any more.
Bob M
07-22-2003 19:32:37
 Re: Re: Re: Minneapolis Moline U Governor in reply to Kelvin, 07-22-2003 18:33:30
That makes sense Kelvin...
I noticed that at speed the governor responds to load changes much better (less RPM droop) without the spring. However it won't pull the engine to low idle unless the spring is in place. I presume when you say I need a "shorter rod" I can bend the gov to carb link to effectively shorten it?
What's threw me is a buddy of mine has an MM "G" equipped with a nearly identical aux spring setup. I just presumed it was stock. (A check of my "U" parts book tonite however shows no spring...)
Kevin Moschenrose
07-22-2003 23:06:52
 Re: Re: Re: Re: Minneapolis Moline U Governor in reply to Bob M, 07-22-2003 19:32:37
Yes, That is what I mean. Bend it slightly to make it shorter and take up the slack in it. This will account for the wear and stretching that the rod has done over time.
Kevin Moschenrose
07-22-2003 07:54:25
Try to shorten the the governor linkage by bending it a little more at the curve. This will help take the slack out and let the carb. will get the feel of the governor.
Bob M - thanks to Kevin/K
07-24-2003 20:06:01
 Re: Re: Minneapolis Moline U Governor in reply to Kevin Moschenrose, 07-22-2003 07:54:25
Tried putting a bit more "kink" into the gov to carburetor rod to shorten it, also removed that extra spring. The governor is now much responsive to changing loads, and it will idle the motor down to dead slow. Thanks guys!!
