Minneapolis Moline Tractors Discussion Forum
Minneapolis Moline H3 Combine and 1200 Cornsheller
Dean Borcher
07-19-2003 18:23:39
I have recently acquired these to items i was wondering if anyone could give me information on them like on the H3 it has a motor i want to know what kind and model so i can replace it and the corn sheller if it was the biggest or what position it was in to be the biggest. your knowledgable help with be priceless to me.
John G
07-19-2003 18:52:45
 Re: Minneapolis Moline H3 Combine and 1200 Cornshe in reply to Dean Borcher, 07-19-2003 18:23:39
The 1200 cornsheller was the biggest, the D smallest, and the E the mid sized one. The H3 is also known as the "69" combine, I have one and sold the motor and put a PTO shaft on it, one less engine to mess with, and the Wisconsin isn't the easiest engine to get along with. The engine is a 4 cyl V type, approx 17 HP @ 1800 RPM. Can't find anything in my advertising literature that gives me the engine model. Someone on this board will know that. I have an excellent air stack for the engine air and one for the carb air. I have parts books, there are always some on ebay, I can find the engine model if you need it. Where are you located? Go to the MM web site for my email. John
Dean Borcher
07-25-2003 12:08:24
 Re: Re: Minneapolis Moline H3 Combine and 1200 Cor in reply to John G, 07-19-2003 18:52:45
You know where i could get the pieces to turn it over to Pto run?
John G
07-25-2003 18:52:10
 Re: Re: Re: Minneapolis Moline H3 Combine and 1200 in reply to Dean Borcher, 07-25-2003 12:08:24
Try on this board or on the MM board, there are quite afew around in certain areas.
Roger
07-19-2003 19:28:59
Sorry John, the 1200 was not the biggest sheller, the "E" 1200 & 1210 were all the same size, updates through the years brought different model numbers. The "B" series would shell more per hour than the others (1400 bushels )
John G
07-20-2003 10:39:45
 Re: Re: Re: Minneapolis Moline H3 Combine and 1200 in reply to Roger, 07-19-2003 19:28:59
Thanks for the correction Roger.
