Minneapolis Moline Tractors Discussion Forum
utu cylinders
moline
07-17-2003 19:26:44
A friend has offered me 2 jugs from a g1000 diesel.Will these bolt on to my utu?I looked on Jeremy Fiorelli's website and it looks like the stroke is the same,bore is bigger.Will the u rods fit on the g1000 pistons(gas pistons).What would the compression be with the stock u heads?Will this combo spark knock on regular gas?Will it even work at all???I dont want a screaming puller engine that fouls plugs at the show,I just want to raise some eyebrows at the dyno tent.Thanks,Moline
Andy
07-17-2003 21:12:37
 Re: utu cylinders in reply to moline, 07-17-2003 19:26:44
It should work if they are both gas or LP tractors. I think the G1000 pistons are a bit taller, you may have to uses a couple sets of block gasckets. The compression will vary depending on your head. If it's a 4209 head I think it would be ok if it's a 4210 higher you may have some preignition problems.
