Use 6V Starter w/ 12V GEN Battery
Trever Maas
07-10-2003 20:52:44
Is their any way I can use a 6V starter on a 12 volt tractor? Would it be fine as long as you don't engage the starter forever? I always thought the 6V starters were built tougher anyways.
Also, does anyone know where to get a starter drive for a UB? I would like to experiment with using one in a 6 volt starter with a 12V tractor nose cone.
I've located 12 volt starters but they go for so much compared to 6V starters. I wanted to experiment a little bit.
Thanks,
Trever
Trever Maas
07-11-2003 06:02:10
 Re: Use 6V Starter w/ 12V GEN Battery in reply to Trever Maas, 07-10-2003 20:52:44
Thanks!
Now all I need is to find a UB starter drive. Any clue?
Thanks,
Trever
Bob M
07-11-2003 04:51:25
Trever - Go ahead and feed your 6 volt starter 12 volts - it'll work fine. I've have a couple on tractors I did 20+ years ago and they are still working fine. Just remember not to crank excessively (more than 30 seconds or so) without letting the starter rest a few minutes to cool.
If the starter is equipped with a solenoid switch (I think all the UB series all are�.), recommend replacing the solenoid with a 12 volt unit. They are cheap - less than $10 - and readily available at any parts store. Ask for a generic (Ford style) solenoid.
deadeye
07-11-2003 02:17:28
Trever:
Hook up the 6 volt starter with a neg. ground and you will be ok. Make sure the selinoid works.
