Removing M5 radiator
Harold
07-01-2003 04:09:15
Any ideas on how to get the little bolts out on the radiator base without twisting them off? I don't think they have ever been removed? Thanks for any ideas. Harold
SWMolines
07-01-2003 11:54:43
 Re: Removing M5 radiator in reply to Harold, 07-01-2003 04:09:15
I soak them with BP Blaster or similar for several day before trying to remove them. Most come out but some twist-off and have to be drilled out. Good Luck!
Chris
10-13-2003 08:21:51
 Re: Re: Removing M5 radiator in reply to SWMolines, 07-01-2003 11:54:43
I am interested in putting a front end loader on a my new 1961 M5. Is this a good idea and does anyone know where I can find one.
Thanks in advance,
Chris
Kevin Moschenrose
07-02-2003 08:24:22
After soaking them, peck a little bit on them with a brass hammer to help shatter and loosen the rust holding on the bolt.The downward blow sometimes forces the bolt to loose its grip with the rust.
Harold
07-04-2003 05:47:05
 Re: Re: Re: Removing M5 radiator in reply to Kevin Moschenrose, 07-02-2003 08:24:22
Worked fine. Soaked them a couple days and then gave each bolt a couple sharp hits with a hammer and they all came out. Didn't twist a one off. Thanks, Harold
SWMolines
07-05-2003 08:29:31
 Re: Re: Re: Re: Removing M5 radiator in reply to Harold , 07-04-2003 05:47:05
You are an extreemly luckly man. Have you considered buying a lottery ticket?
