UB leaking water in oil
Brian
06-28-2003 15:08:05
I have a UB that has water getting in the oil someway. I pulled the heads and had them tested for cracks and couldn't find any. I"m going to take the blocks in Monday, but the machine shop dosn't think that is where the problem is. Head gaskets were OK. Any other ideas what could be wrong. Water pump? It is a LPG. Thanks for any help. Brian
Larry O.
06-28-2003 16:25:44
 Re: UB leaking water in oil in reply to Brian, 06-28-2003 15:08:05
Yep you guessed it. Water pump seal. Easy to install. Just make shure you sand all surfaces smooth where the seal contacts metal. They are not expensive less than $10.00 at Agco.
Brian
06-30-2003 17:02:33
 Re: Re: UB leaking water in oil in reply to Larry O., 06-28-2003 16:25:44
Larry, Thanks for the answer. Brian
