Minneapolis Moline Tractors Discussion Forum
More power for MM UTS
Texas Red1
05-26-2006 17:35:42
I had to change my name to get back in to post, what is going on with that??
Now my question: I am going to put a GB crank, cam, blocks,pistons and rods, and 4210 heads into my uts, some of the info i see, said that the comp ratio would 9 to 1. is this right. Do i use the GB cam of do i need to have reground? What kind of horse power will i see? going to put new rings and new valve job in it also. i will be changing the 30 inch tires to 18.5 x 34s I guess what i need to know is there anything i need to get it right? Thanks for the help TR
Harrold Rhodes
05-27-2006 17:32:13
 Re: More power for MM UTS in reply to Texas Red1, 05-26-2006 17:35:42
If the blocks and pistons are std. the 4210 heads should should be 9.1 to 1 comp. The GB tractor on lp was rated at approx 66 pto hp. Of course engine speed affects hp. I'm not familiar w/cams.
