Road Grader / Motorgrader
Sam
06-08-2003 19:37:33
I have a M-M Grader powered by a four cyclinder gas engine. It has a 12 foot blade operated by hydraulics, including side-shift. It runs well and I'm using it to grade my driveway. I don't find the model number (4 1/4x5 283 4A) listed. Where might I find more information?
husen
04-08-2004 08:21:18
 Re: Road Grader / Motorgrader in reply to Sam, 06-08-2003 19:37:33
giv me all details of graders + prices + pics
don kettering
06-10-2003 18:49:02
I have an American Grader with a MM U LP tractor as the power source. If any one is interested make me an offer I can not refuse.
Lowell
06-09-2003 18:23:20
What you describe was probably made by the American Grader Co. of Omaha, Ne. sometime between 1950 - 52. I have one with serial # 03900095 also known as an American 900. It is a MM UTSG with a 283 engine.
Joe
06-09-2003 09:46:25
Hi Sam,
Look along the right side of the transmission housing, just under the opperators platform. There might also be a tag along the left side of the grader frame about in the halfway point of the tractor. I have a UG made by American Grader company using a MM U as the power unit. They made only 125 of these units. If you need more info just ask.
Enjoy, Joe
Bob
06-09-2003 08:01:15
I'm not a MM expert, but I would suspect the grader was built by someone else, using the MM engine and rear end. I used to have an old Gallion blade with a Hart Parr tractor as the power unit, and they, or other companies may have used MM's. Check the main beams that arch up over the grader blade. Often, there is a nameplate in this area.
Jim
06-08-2003 20:43:20
The number you posted is the engine model number, not the model number of the machine. This engine was used in the U series tractors.
Sam
06-09-2003 06:53:41
 Re: Re: Road Grader / Motorgrader in reply to Jim, 06-08-2003 20:43:20
Jim.
Thanks for the info. I'll look for the other model number tags. If you know where they may be, please let me know where to look. Thanks again.
Sam
