Sediment bowl for model R
Corvairkid
06-08-2003 09:27:51
I am looking for a sediment bowl for my B.F. model R, any idea where one can be found?
Thanks,
Corvairkid
Kelvin
06-08-2003 18:22:02
 Re: Sediment bowl for model R in reply to Corvairkid, 06-08-2003 09:27:51
If that bowl is like the one on my BG that screws into about a 3/8" pipe fitting welded in a bar that sticks out from the right side of the gas tank, I got the whole assembly from NAPA. Bowl about 2" or 2-1/2" deep.
Also, Tractor Supply usually has them.
G. L. Perry
06-08-2003 09:44:27
Have you tried AGCO dealers or other brands. Case/IH has lots of bowls. Motec Engineering claims to have bowls for MM's, not sure if that includes Avery models or not. He's in Tipton, IN. Link is on MM home page or maybe even here if you look. I see bowls AND the gaskets at tractor shows with swaps alot. Gasket is hardest part to find seems.
