UTU Manifold
Matt
06-03-2003 18:29:26
Was wanting to get a little more power out of my UTU and I was told there are larger intake bore manifolds made for the 283 MM engine. Was wondering if anyone knew anything about this or if a manifold off a newer or larger Minneapolis Moline tractor might fit also. I noticed the bore in the manifold intake was much smaller than the carb bore so I assume more air, more power??? Also any other tips on pulling these old girls would be apprecated for instance what did they weigh off the line anyway??
Lynn
06-08-2003 08:35:57
 Re: UTU Manifold in reply to Matt, 06-03-2003 18:29:26
I have an M-5 intake and exhaust manifold setup if interested, e-mail me.
Matt
06-10-2003 09:24:41
 Re: Re: UTU Manifold in reply to Lynn, 06-08-2003 08:35:57
Yes I would be very interested. Pulled the old girl this weekend and was beat by 110 feet and I don't want to do that again. I think this might help a little bit anyway. Just drop me a line at [email protected] or just give me a call and tell me what you need for it and where you are located. I also want to be sure it will fit before I make any decision. Thanks, Matt Abbas, Latimer Iowa 515-290-6123
Trever Maas-MN
06-04-2003 08:04:35
Hi Matt,
I know that pretty much anything will interchange on the 4 cylinder MM's except for the carb on some occasions. I'm using a newer style manifold on my 49 UTS, looks to be an M-5 manifold. Don't know if it's good for it but it did the job and runs beautifully, when the needle valve doesn't stick in the carb. :)
Trever
