Seat Rubbers? and muffler?
G. L. Perry
05-21-2003 01:30:03
Have an M670, needs those rubber bands for seat on back. AGCO wants $42 EACH and two needed. Anyone else have a source? or used springs or ???
I need a muffler too. I would like to have the clamp above the hood, as I may need to remove it to get in garage door. It's a Pain working under the hood to get off. My thinking is to have a muffler shop make a pipe with expansion to fit over my exhaust header and have new muffler slip over it on top of hood. Only thing bad is the look of clamp up there. Should there be any reason the longer length will bother tuning or such on engine? Anyone have a muffler #, say from Tractor Supply or ? so I can ask quicker for one?
Are the oil and air filter cartridges hard to find for a 670? I'm thinking air one may be anyway. Anyone have modern #'s for those two filters? I can Get WIX locally or go to TSC again.
Aron
05-21-2003 16:15:53
 Re: Seat Rubbers? and muffler? in reply to G. L. Perry , 05-21-2003 01:30:03
Yup $42 plus tax. I had to bite the bullet and pay that same amount for the bands. Those are also the first parts to find missing on a lot of those seats. I have had 670, JS3, 302, and a 604 with a similar seat assembly and only the u302 had every intact seat part. The muffler shop is the best alternative for a longer pipe. I have ran into a few aftermarket exhaust manifolds that have come equipped with a longer pipe that enables clamping above the hood, but a muffler pipe extension should be cheaper than a new exhaust manifold. I had luck with buying 2 MM air filters off the shelf at an Agco dealer in Bement, IL. I wish they had 100 more of them!!!
For good reliable MM advice and parts I try the good folks at River Dale Farms.
