UTU fenders
dlp
05-04-2003 19:12:11
I have a '46 UTU. The clamshell fenders I have look like there should be a bracket between them & the axle. Is this right?
Kelvin
05-04-2003 19:21:47
 Re: UTU fenders in reply to dlp, 05-04-2003 19:12:11
Actually, If you need the bracket (I assume the bolt pattern is 2 bolts through the bottom of the fender) then your fenders were originally intended for either Z's, ZA's or later U's(about '50 and up.) The original fenders had 3 bolts on a u-shaped mount that fit the axle.
You will need the later U fender mounts to mount your fenders to the axle.
