Pistons
Jcnc
05-02-2003 13:19:19
My nephew is working on a MM, and found that two of the pistons are flat, and two have raised tops. Would this indicate that two have been replaced? Any reason why the factory would have installed them that way? Thank you for your ideas and info.....
Kelvin
05-02-2003 17:28:51
 Re: pistons in reply to Jcnc, 05-02-2003 13:19:19
Should be either one way or the other. Any clue what model it is?
Jcnc
05-03-2003 05:43:29
 Re: Re: pistons in reply to Kelvin, 05-02-2003 17:28:51
I just spoke with my nephew and he said the tractor is a 1950 RTE. Thanks for your info.....
Kelvin
05-03-2003 17:40:27
 Re: Re: Re: pistons in reply to Jcnc, 05-03-2003 05:43:29
Then it should have pistons with domes on the valve side on all four cylinders.
Jcnc
05-04-2003 05:01:38
 Re: Re: Re: Re: pistons in reply to Kelvin, 05-03-2003 17:40:27
Thank you for the information. Looks like someone replaced with the wrong item. Compression in those cylinders with the flat pistons is probably lower than it should be.....
John G
05-04-2003 18:10:50
 Re: Re: Re: Re: Re: pistons in reply to Jcnc, 05-04-2003 05:01:38
Maybe you should check the compression, I've been told that there are pistons with the pin in the right height to make up for the domed piston compression. Just a thought. An R runs with no power with Z flat top pistons, not enough compression. ie: pin in the wrong place??
