UTU clutch, More HP
Matt
04-15-2003 20:48:03
Need to know how to adjust the clutch on this UTU I just bought. Likes to slip when I put it under a good load. So far very impressed. Lots of power, comparable to my 44 Massey. By the way, I would like to pull it this summer. Any way to add 10% to my HP? I say 10% because thats all my club allows. Maybee a 5* or other 283 manifold, carb and or govener? Maybee I don't even need it. Was using it to pull chunks of concrete foundation out of the ground today and it just luggs em right out.
STEVE HARDEN
04-16-2003 21:11:15
 Re: UTU clutch, More HP in reply to Matt, 04-15-2003 20:48:03
I DON'T HAVE THE U BOOK IN HAND HOWEVER; I BELIEVE THE CLUTCH ADJUSTS UP THE SAME AS THE GB)WITH CLUTCH COMPARTMENT COVER REMOVED AND TRANSMISSION GEAR SHIFT LEVER IN NEUTRAL, ROTATE ENGINE CRANKSHAFT UNTIL THE LOCKPIN IS ACCESSABLE; THEN PULL THE PIN OUT AS FAR AS IT WILL GO. PLACE THE TRANSMISSION IN ANY GEAR THEN DISENGAGE THE CLUTCH, AND ROTATE THE ADJUSTING YOKE TO THE RIGHT (OR UP AS IT IS VIEWED FROM THE OPENING) TO TIGHTEN CLUTCH. TIGHTEN UP TILL THERE IS NO SLIPPAGE UNDER A FULL LOAD, YET NOT SO TIGHT DIFFICULTY IS ENCOUNTERED WHEN ENGAGING THE CLUTCH. SHOULD HAVE A PRETTY GOOD SNAP TO IT. (FEEL FREE TO CORRECT ME IF I'M WRONG) SORRY SOMEONE ELSE WILL HAVE TO HELP YOU WITH INCREASING YOUR HP GOOD LUCK!
