Utu govenor problem
joe
04-08-2003 18:22:10
have a good running utu but am having trouble with govenor have had apart and can not really find any problem .
any suggestions
thanks
Tim Heitman
04-08-2003 18:50:20
 Re: utu govenor problem in reply to joe, 04-08-2003 18:22:10
Check your linkage from gov to carb with thottle wide open and carb wide open linkage rod should fit into both holes without any friction. You can bend rod to fit perfectly.
deadeye
04-09-2003 04:37:28
 Re: Re: utu govenor problem in reply to Tim Heitman, 04-08-2003 18:50:20
Tim is on the right track, but I think the book says half the thickness of the linkage rod as the wide open adjustment. Can't remember. Better check the book.--deadeye
