Uts
jerry
04-08-2003 16:47:46
i need an exhaust manifold for 1950 uts, where is a spot to find them?also the engine is stuck is it a good idea to free the engine by pulling in high gear and letting the clutch out slow?
Kevin Moschenrose
04-08-2003 22:03:25
 Re: uts in reply to jerry, 04-08-2003 16:47:46
I wouldn't unlock one that way. Most of the time you do more damage to them then what is really wrong to begin with. I would let it soak awhile first. Then if that doesn't work then tear it down and press them out. I soak mine in PB Blaster and gun bore cleaner. Are you looking for a new one or a good used one?
jerry
04-12-2003 08:09:05
 Re: Re: uts in reply to Kevin Moschenrose, 04-08-2003 22:03:25
thanks kevin for the information.looking for used one without any holes or cracks,or new if i cant find one.where a good place to buy mm parts?
