R: wheel and tire sizes
Keith
03-31-2003 17:38:08
I need to know what an R MM came out with for wheel and tires sizes, front and back. It has a wide front if that makes any difference. Thanks.
Kevin Moschenrose
03-31-2003 23:18:54
 Re: R: wheel and tire sizes in reply to Keith, 03-31-2003 17:38:08
Fronts are 5.00-15 part#11a1136
6.00-16 part#11a862
Rears are
9-36 part#10a1509
9-38 part#10a1799
10-34 part#10a1729
10-38 part#10a1508
11-38 part#10a372
That covers all R's except RTI's I have those too if you need them.
Keith
04-01-2003 16:00:30
 Re: Re: R: wheel and tire sizes in reply to Kevin Moschenrose, 03-31-2003 23:18:54
Thanks. Were there any size(s) specific to an R with a wide front end? It has 16" on the front. I need a pair for the rear.
Jack
04-04-2003 20:05:09
 Re: Re: Re: R: wheel and tire sizes in reply to Keith, 04-01-2003 16:00:30
You need to post your rim size or the size of the tires presently on it. If you have a wide front it could be an RTI which had 24" rears. What you definitely need is to figure what size rim and then someone can go from there. Tractor SN wouldn't hurt either if you have it.
Keith
04-06-2003 06:06:16
 Re: Re: Re: Re: R: wheel and tire sizes in reply to Jack, 04-04-2003 20:05:09
It has no rear rims or tires. It is an R with a wide front with 16" fronts. I'm looking for 38" rears.
