When to fix cracked heads
Mike (MI)
03-28-2003 04:47:09
I'm working on a 1960 M5 diesel with 10A4222 heads. One head has been replaced with a head that has the same casting number, but is obviously newer. On both heads, there is a crack that propagates from the injector hole to the deck of the head, and also towards the exhaust valve. When it was running, it didn't pressurize the coolant system, and it wasn't using any water. I'm rebuilding the engine and would like to do things right. Should I spend the money to have them welded, or just figure that if it hasn't leaked yet it isn't going to? Any thoughts or experience with this is greatly appreciated.
Kevin Moschenrose
03-28-2003 08:55:28
 Re: When to fix cracked heads in reply to Mike (MI), 03-28-2003 04:47:09
My 5-star diesel was the same way. My local Agco/ old MM dealer said that was not too uncommon for them to do that. It how ever was going to cost a pretty penny to fix. I was lucky to find a pair of heads off of a M670. They were checked for leaks and were guaranteed. I would check on a price to fix it first before I went any farther with it. Just because it is not leaking now it may not be too much more before it starts. That's my .02 cents. Hope this helps.
HAVVEY
03-28-2003 17:13:36
 Re: Re: When to fix cracked heads in reply to Kevin Moschenrose, 03-28-2003 08:55:28
NEVER HAD MUCH LUCK WELDING A COMBUSTION CHAMBER EXTERIOR CRACKS ARE ANOTHER MATTER I WOULD TRY TO FIND GOOD HEADS
