SEALED BEAM (REPLACEMENTS) FOR A GB ?
STEVE
03-09-2003 17:55:29
IS THERE A MODERN DAY REPLACEMENT FOR THE SEALED BEAM HEADLAMPS ON A GB (6" 12V ORIGINAL NUMBER
#10P359) WITHOUT HAVING TO MODIFY THE HEAD LIGHT ASSEMBLY ????
OR PERHAPS SOME ORIGINALS SOMEPLACE THAT WON'T TAKE YOU FOR AN ARM OR A LEG ?????
THANKS!
Andy
03-10-2003 12:09:22
 Re: SEALED BEAM (REPLACEMENTS) FOR A GB ? in reply to STEVE, 03-09-2003 17:55:29
I use Wagner 5001 sealed beam halogen. They are the high beams for a 4 round headlight car. they are about $5 and very bright. you have to cut a couple notches in the housing for the alignment notches.
STEVE
04-01-2003 16:22:52
 Re: Re: SEALED BEAM (REPLACEMENTS) FOR A GB ? in reply to Andy, 03-10-2003 12:09:22
THANKS FOR THE WAGNER 5001 TIP (I GAVE UP ON THE ORIGINALS IDEA). ACTUALLY THE VERY BRIGHT LIGHT SOUNDS GOOD.
I GOT THE 5006 SAME LAMP, SAME $6 PRICE ACCEPT HAS A BRIGHT & DIM (2 LAMPS IN ONE).
THANKS AGAIN STEVE
John G
03-10-2003 05:49:44
Steve, NAPA used to have a GE bulb catalogue which showed all the sealed beam lights by size and voltage and any other pertinent info. Maybe a parts store near you will have the same type catalogue.
