What is the hp difference
david e stephen
03-09-2003 13:36:05
what is the difference in horsepower between a jetstar2 and the 445 molines
pete-mi
03-14-2003 19:40:31
 Re: what is the hp difference in reply to david e stephenson, 03-09-2003 13:36:05
They have the same engine. The biggest diference is the Jet Star 2 has the updated tel-o-flo hyd system with extrenial plumbing. It seems to hold up a little better.
Jim Parisot
03-11-2003 10:26:33
David,
According to Nebraska tests the 445 tested at 39.87 H.P. at the Belt, maximum corrected in the Universal tractor on gasoline. The Utility tested at 39.97 H.P. The Jet Star 2 was never tested as such, but had the same engine as the tested 4-Star which showed 44.57 H.P. at the PTO, also on gasoline. Hope this helps.
Jim
david e stehenson
03-13-2003 08:10:26
 Re: Re: what is the hp difference in reply to Jim Parisot, 03-11-2003 10:26:33
thanks guys for the info on the hp 0f the2jet star and 445 moline, iam looking at buying a 2 jet star in northern iowa as 445 are getting harder to find, i use my uncle in southern ia till he sold it. we have three moline estate sales in north west iowa in april and june that i am going to attend.
Don
03-10-2003 18:34:19
I looked im I&T shop service manual. I did not find HP rating, but they both appear to be 206 cu.in. with a 7.3:1 compression ratio for gas. They have different engine model numbers. The 445 is 206H and the Jetstar is 206L-4. According to my brother, who is pretty knowledgeable about Molines, the 445 is 41 HP and the Jetstar is 44HP.
Kelvin
03-10-2003 18:47:29
 Re: Re: what is the hp difference in reply to Don, 03-10-2003 18:34:19
I'm thinking that if they use the same heads, same bore and stroke, same carb., same manifold, the hp. difference could only be because the governed wide open throttle is higher on the jetstar. And probably wouldn't be that noticeable.
