R, Size dimensions
Jeff S
03-09-2003 07:09:25
I am attempting to talk my wife into bringing home a 49 RTU. The R will probably push my car out of the garage. I need length (back of rear tire to nose) and width (rear axle) if anyone has it. Also for hauling reasons I figure an RTU to weigh just under 2900 pounds is that correct?
Thanks
Roger Roemen
03-09-2003 16:51:20
 Re: R, Size dimensions in reply to Jeff S, 03-09-2003 07:09:25
10 feet long and 6 feet wide will get it inside with no room to work. The weight will be closer to 3100 depending on tires weights or fluid. good luck, Roger
