Mounting a snow plow on a UB
John UB
02-26-2003 09:45:45
I'm looking for pictures or suggestions on how to mount a snow plow on a 1954 UB. Does anybody have any pictures of a set up that works well?
Thanks for all the help.
Andy
02-27-2003 10:12:50
 Re: Mounting a snow plow on a UB in reply to John UB, 02-26-2003 09:45:45
I would consider mouning it on the rear. There are two holes in the angle iron for the drawbar frame To work with. You could probably use the cultivator lift. You won't go as fast in reverse but if you get stuck or need to go throught heavy snow you can lift the plow up and put a lot of wieght on the drive wheels. I did this on a ZB and if you lift hte plow about an inch or two off the ground you can push through some real deep snow. You can go back and run it all the way down a secound time. You can pop wheelies too!
