U302 waterpump
jerry
02-21-2003 17:40:19
I RECENTLY OVERHAULED MY 302 AND AFTER ASSEMBELY THE WATER PUMP STARTED TO LEAK. I REPLACED THE SHAFT AND BEARING, SEAL AND RETAINER SPRING BUT IT CONTINUES TO LEAK FROM DRIAN HOLE LOCATED BEHIND SEAL ANY HINTS TO CORRECT THIS PROBLEM
Gordon
02-22-2003 06:35:58
 Re: U302 waterpump in reply to jerry, 02-21-2003 17:40:19
You might have cracked the porcelain washer or up side down.
JK
02-22-2003 06:02:49
The surface on the impeller that the seal runs against is sometimes rough & needs to be resurfaced to seal properly. It could also be seeping around the seal in the case if you didn't use any sealant when installing the seal.
John
