UTS weight???
Farmall Boy
01-23-2003 20:25:11
how much a uts weigh with wide front and all stock other parts stock
BLT
01-25-2003 06:50:54
 Re: UTS weight??? in reply to Farmall Boy, 01-23-2003 20:25:11
The 1947 Tractor Field Book published by Farm Implement News Co. says the UTS shipping weight with 12-38 tires is 5250 lbs.
John G
01-24-2003 05:52:14
My '50 UTS LP weighs 6470#, has 16.9x30 tires on 16" rims, 2 rear wheel weights on each side, no fluid, with me on it, 180#
Kevin Moschenrose
01-23-2003 22:30:53
The weight is real close to 6220 lbs.
clint
01-24-2003 07:35:50
 Re: Re: UTS weight??? in reply to Kevin Moschenrose, 01-23-2003 22:30:53
ours has 18.4x30 tires and no wieghts. It scaled at 5560 with me on it that is with all sheet metal
Clint
Kelvin
01-24-2003 16:49:59
 Re: Re: Re: UTS weight??? in reply to clint, 01-24-2003 07:35:50
I weighed my '54 at tractor pull: 5955#, 16.9 tires, no fluid,stock 403 engine, and 2 weights each rear wheel.
Kelvin
01-25-2003 17:48:47
 Re: Re: Re: Re: UTS weight??? in reply to Kelvin, 01-24-2003 16:49:59
Sorry, should have mentioned tractor had all stock sheetmetal platform seat, and etc. I did not pull, just weighed on their scales.
Family Tradition
01-25-2003 11:44:03
my 52 uts is stripped down, fiberglass pan 16.9-38 tires, weight brackets, wheelie bars, disc brakes, and should be able to pull 4750..... have not weighed since converting to the disc brakes..... i am also running tall jugs
ah duh!
01-25-2003 13:06:13
 Re: Re: Re: Re: Re: UTS weight??? in reply to Family Tradition, 01-25-2003 11:44:03
Nothing was mentioned about a pulling tractor and it's weight. There was a mention of "STOCK" partS though. DUH!
