Question about plow
Walker
01-13-2003 18:29:29
I have a three bottom M.M. plow on rubber and it is hydraulic lift I was wondering how I can figure out what model it is?? I am also tryin to find a M.M. hydraulic cylinder for it. Thanks for the help. Scott Walker
John G
01-13-2003 18:50:01
 Re: Question about plow in reply to Walker, 01-13-2003 18:29:29
Where are you located Scott? I have some MM hyd cyl, for sale, but not to ship. Also have plow literature, for reference, not for sale. I'd guess you have an AF or DF plow, but can't besure without a better description.
Walker
01-13-2003 19:07:57
 Re: Re: Question about plow in reply to John G, 01-13-2003 18:50:01
I am located in Northwest Indiana, Rensselaer. Is there a number somewhere to go by?? It has the levers to level the plow and it the hitch is adjustable and sits kinda low to the ground. How much are you asking for the cylinder?? Thanks for the help. Scott
John G
01-14-2003 19:35:51
 Re: Re: Re: Question about plow in reply to Walker, 01-13-2003 19:07:57
Scott, The most common plows are the AF which has 2 beams at the hitch plate. This plow may be 2 or 3 bottoms, the DF plow has 3 beams at the hitch plate and may be 3 or 4 bottoms. These were all available with the clutch lift or the later Uni-Matic hyd lift. I sent you some pictures, let me know how they come thru. John
Walker
01-15-2003 08:59:54
 Re: Re: Re: Re: Question about plow in reply to John G, 01-14-2003 19:35:51
Thanks for the pics i believe my plow is an AF Thanks for the help. Scott
Peter J
01-15-2003 03:31:58
John,
I too am looking for a MM hydraulic cylinder. Where are you located?
PJ
John G
01-15-2003 05:04:40
 Re: Re: Re: Re: Re: Question about plow in reply to Peter J, 01-15-2003 03:31:58
I'm 40 miles from Chicago, 40 miles from Milwaukee, and 15 miles from Lake Michigan, Antioch, IL. Want $60.00 per cylinder, have 3" and 4" cyls.
