Old MM 2 row self propelled corn picker
Rick
01-10-2003 11:14:21
I have come across an old 3 wheel Minneapolis Moline 2 row corn picker. Really unusual factory machine. Just wondering if anybody knows anything about these old machines. It's in pretty darned good shape, motor not running, but don't think it'll take much to get her going. I've never seen one before. Are they rare? What might it be worth? I think I'll try to buy it, just because it's so unique, just wondering what some of you guys thought. Thanks, Rick
BMG
01-10-2003 14:25:58
 Re: Old MM 2 row self propelled corn picker in reply to Rick, 01-10-2003 11:14:21
Rick,
Sounds like you've found a Uni. Model L on the serial # tag on the frame behind the motor I believe. Not really rare but not many around in collectors hands because they're hard to haul since they're over 8' wide. I've got 2 with several rotted out pieces of equipment. I've got a pretty good corn picker still mounted on one. The only reason I've got them is because they were local and I drove them home. They're both stuck now and take up too much room. I'll probably get rid of one of them in the spring along with all the attachments except the picker. The early versions had a flat head motor similar to an R or Z tractor engine. The later versions had an overhead valve engine based off of the 445 type engine. I wouldn't give too much for it unless you really have to have it. I'd guess somewhere in the $100-$500 range if its really nice. Running would be a big plus.
Brian
