UTS Steering Wheel and Shaft
Trever Maas-MN
01-08-2003 17:01:37
Is their any other model that interchanges with this model for this part? I need from the wheel to the steering box or the knuckle.
Thanks,
Trever
Kelvin
01-09-2003 16:38:54
 Re: UTS Steering Wheel and Shaft in reply to Trever Maas-MN, 01-08-2003 17:01:37
Maybe GB's use the same shaft. There are a lot of UTS's out there. Get on the MM website and start calling parts suppliers. Everett, Welters or Balcom probably will sell you one.
Another idea:
If you don't need the steering shaft support or the bearing in it, you can just cut down a UTU shaft and drill a hole through it. It should be the same 1" dia. Steering wheels interchange too.
Trever Maas-MN
01-09-2003 19:49:00
 Re: Re: UTS Steering Wheel and Shaft in reply to Kelvin, 01-09-2003 16:38:54
I'll send you a PM.
Thanks,
Trever
