Motor spec.
Rocky
01-01-2003 10:41:01
I have a late model M-M U with the 4 5/8 bore on it. It also has the 10a4209 heads on it. Need to know how much to torque the heads to and also valve setting.Thank you and Happy New Year!
william foster
01-09-2004 08:31:57
 Re: Motor spec. in reply to Rocky, 01-01-2003 10:41:01
am looking for any info on 1978 f 250 400m specs all info on this matter would be thankfull
dlp
01-01-2003 18:33:48
I'm assuming you are referring to a UB gas. The book says to torque the head nuts to 102 ft/lbs on the camshaft side & 86 ft/lbs on the exhaust manifold side. It also says to tighten the nuts on 9/16 studs to 68-72 ft/lbs. Valves are set hot at .008 inlet & .010 exhaust.
