Slobering 585 mm
Turbine Dude
12-28-2002 20:02:13
What causes these engines to slober oil out the seams of the exuast manifold? Thanks T-D
answer
12-29-2002 08:13:34
 Re: Slobering 585 mm in reply to Turbine Dude, 12-28-2002 20:02:13
The 585 is victim of the MAN system. A foreign purchased injection system. It was the cheap by when the tractors were built. It blows.
MM Dude
01-06-2003 20:56:29
 Re: Re: Slobering 585 mm in reply to answer, 12-29-2002 08:13:34
It's obvious you don't know what you're talking about. The direct injection diesel if anything is a little cold natured, but is a very smooth and powerful engine. MM never made injector pumps, but not many tractor manufacturers ever did. If the engine is blowing oil, it probably needs at the least a ring job, but more likely a rebuild - bore with new pistons (give the pistons slightly more clearance than the book says). The 585 is a very good engine if it's built right and maintained properly. Find an external oil pump if it doesn't already have one. The motor is a horse!
StuZ
01-01-2003 16:28:09
Does it run at a low idle alot ??
That will do it
Turbine Dude
01-04-2003 08:57:22
 Re: Re: Re: Slobering 585 mm in reply to StuZ, 01-01-2003 16:28:09
No but it hasn't been worked hard either alot of runnig around ect
