Model L uni-tractor
gregg
12-28-2002 19:41:38
I came across a model L uni tractor that is complete but stuck and was wondering if these are in demand for restoring and if so what price range do they run.Thank you!
Mike Tessman
12-30-2002 17:35:14
 Re: Model L uni-tractor in reply to gregg , 12-28-2002 19:41:38
Greg: I have 2 uni's. One is the 46th one made and it is in very good condition. It has always been shedded. The other is a 54 model. Both have corn pickers mounted on them. I gave $250.00 for each one. I agree that they are hard to transport, but they would be an eye catcher at any antique show. If you can buy it right, go for it. Mike
Kelvin
12-30-2002 16:57:14
They share many engine components with other MM tractors. Early ones used the same blocks as MM Z's and later ones used the same blocks and heads as MM 445's. I think the pistons were same as on the tractors, also. Also, the carburetor is same as a MM Z,ZA, or ZB, so even if not restorable, A Uni model L would be worth something as parts. The gas tank is same as on MM R, the seat was used on a number of MM tractors-R,Z,U,G.
MIke (WA)
12-30-2002 09:30:33
There doesn't seem to be a big demand because of the difficulty in hauling to shows (width). It would be great to save some of them- I've only seen one in many years of going to "moline-intensive" shows.
