PCV valve on Super 670
Pat
12-28-2002 17:09:29
My super 670 wants to suck up excess oil from the rocker arms into the tube exiting the valve cover via the PCV valve into the intake. I know the engine is in good shape, oil pressure set correct, steel rocker arms I believe with screws in the oil holes on rocker arms to restrict oil previous owner fix I'd suppose, no metering rods in oil tubes coming from cam journal up to rocker arms. What would a good MM man say is the best fix, install metering rods, install pipe cleaners in tubes, weld baffle under valve cover, change rocker arm assemblies? LP 336 engine. Thanks
Harrold Rhodes
12-29-2002 10:44:50
 Re: PCV valve on Super 670 in reply to Pat, 12-28-2002 17:09:29
The PCV system used very successfully on MM power units for years because the steady load they were under in my opinion was not as successfull on tractors. When under light loads the vacum created sucks oil and in some cases dirt into the intake and the engine. My solution was to go back to letting them breath naturally and plug the intake manifold off.
Harrold Rhodes
12-29-2002 10:43:35
