Minneapolis-moline g1350
james r. corder
12-15-2002 21:05:56
i'm trying to find out if the minneapolis-moline G1350 could be bought from the factory with the narrow front end, commonly referred to as a tri-cycle front. i do not know, also, what about the G1355, did it have available a narrow front end?
JAMES R. CORDER
12-22-2002 08:45:16
 Re: minneapolis-moline g1350 in reply to james r. corder, 12-15-2002 21:05:56
THANKS FELLOWS FOR RESPONDING ABOUT MY QUESTION AS TO WHETHER THE MINNEAPOLIS-MOLINE G-1350/G1355 COULD BE HAD WITH A NARROW FRONT END. IT SOUNDS LIKE IF YOU HAD WANTED ONE, IT COULD HAVE BEEN ORDERED FROM THE FACTORY. MAYBE. ANYHOW I HAVE SEEN G1000 VISTA'S WITH FACTORY NARROW FRONT ENDS AND FRONT WHEEL ASSIST AS WELL AS STANDARD AND WIDE ADJUSTABLE. I THINK THE MINNEAPOLIS-MOLINE TRACTORS ARE SOME OF THE FINEST EVER PRODUCED AND I COLLECT LITERATURE AND TOYS ON THEM. I DON'T OWN ONE AS I LIVE IN TOWN AND HAVE NO STORAGE FOR IT. I DID USE, A 1948 M.M., U, ON THE FARM WHERE I GREW UP, IT WAS A STANDARD WHEATLAND TYPE AND WAS A HANDFUL FOR A 10 YEAR OLD. AGAIN THANKS FOR ALL OF YOUR RESPONSES. JAMES
John
12-16-2002 18:25:42
Welters in Verona, MO have a G1350lp with a factory narrow front, I think they bought it new.
Blaine Griggs
12-16-2002 22:41:00
 Re: Re: minneapolis-moline g1350 in reply to John, 12-16-2002 18:25:42
John,I only live about 80 miles from Welters.They pulled that NF G-1350 LP tractor in the 13,000 lb stock class for years.I used to pull my 856 IH against it.It sure did look like a factory narrow front.
m kuhns
12-17-2002 18:57:45
 Re: Re: Re: minneapolis-moline g1350 in reply to Blaine Griggs, 12-16-2002 22:41:00
Easy to make look stock when everything bolts right into place.
m kuhns
12-16-2002 14:05:04
I'm pretty sure neither of these had narrow fronts. We put one on our Oliver 2155 to pull with. It is the same tractor as the g-1350. Ours came with a wide front similiar to a 2-150 White front end. The narrow front we added was an Oliver front like off an 1850.
Kevin Bauza
12-19-2002 16:37:40
 Re: Re: minneapolis-moline g1350 in reply to m kuhns, 12-16-2002 14:05:04
Is your picture on Larry Harsin's website? There is a 2155 pulling picture. If not, check it out at www.olivertractor.com (or .net??)
m kuhns
12-21-2002 07:41:19
 Re: Re: Re: minneapolis-moline g1350 in reply to Kevin Bauza, 12-19-2002 16:37:40
Yes the picture of the Oliver 2155 is our pulling tractor. Not too pretty but works good
freddy
12-16-2002 09:17:47
I have a original brochure. all that is listed is a standard front and a adjustable row crop. My G1000 manual shows a narrow front end.
Shep
12-16-2002 10:19:49
 Re: Re: minneapolis-moline g1350 in reply to freddy, 12-16-2002 09:17:47
Yeah, thats right I have seen a G-1000 with a narrow front. I think 100hp was about the limit on what they put narrow fronts on though.
Shep
12-16-2002 07:53:38
No, I dont think so, those two tractors were too large to come with a narrow front end option. I think the biggest row crop tractor I know of you could get with a narrow front was the 1950 Oliver, not sure what the biggest Moline that had a narrow front was, I know the M-5 had a narrow front option and the M-670 also.
Harrold Rhodes
12-17-2002 19:20:41
 Re: Re: minneapolis-moline g1350 in reply to Shep, 12-16-2002 07:53:38
Any of the narrow fronts, trycycle or single from the UB Special on would fit on the larger tractors but they would be awful heavy on them. I'm sure a lot of the wide fronts were removed for weight by the pullers and the narrow fronts of the smaller tractors would qualify as factory.
Harrold Rhodes
12-17-2002 19:19:01
