Removal of broken copper nipple
JKC
12-15-2002 05:36:10
I am servicing a Marvel Schebler carburator from my 1950 MM ZAU. There is a 90 degree elbow nipple that connects the gas line to the carb. This COPPER nipple screws-in to the carb and I broke it off inside. Have no idea how to get it out now. Have tried traditional methods without success, as the copper is soft and just keeps changing shape. ANY suggestions at all would be appreciated. I am at a roadblock here! Thanks.
Dave
12-16-2002 19:37:18
 Re: Removal of broken copper nipple in reply to JKC, 12-15-2002 05:36:10
This is a longshot, but I don't think it is a copper nipple, but more likely a brass nipple. If you can't get it out with extracter bits, etc. But you can break the carb down to just the main cast iron carb body, you could just cook it up with a torch, the brass should melt out before any problems with the cast. BE CAREFULL
I would try drilling it out without knocking any edge off of the cast iron threads. Then get a tap, probably 1/4ntp, double check the original thread dementions and retap the hole, more than likely it will start to "chase" the original threads and lift the brass out. Good Luck
