Mmrtu crank help
peter
12-07-2002 12:32:32
crank may be bad can i use a zb crank with longer strock?? is it worth putting money into rtu motor for pullin ?? help peter
John G
12-07-2002 14:51:00
 Re: mmrtu crank help in reply to peter, 12-07-2002 12:32:32
Crankshafts do not interchange between the EE, RE, and 206 engines. All the complete engines will interchange using the correct flywheel. I have a '37 JTU with the 206 out of a ZA in it. The crankcases in the 3 variations are entirely different. They can all use the same internal parts except the crankshaft & bearings and rods & pistons. When boring an EE engine, you have to use domed pistons, or the LP head to make enough compression to run right, the oversized R pistons are VERY hard to find and more expensive that the LP head.
