Pulling tractor
B R sears
12-01-2002 09:11:54
found a 1951 u lpg need help with know how and
part choice. mostly JD tractors around here. would
like to put MM in front of JD for a change.THANKS
Andy
12-01-2002 09:26:48
 Re: pulling tractor in reply to B R sears, 12-01-2002 09:11:54
If it runs good and you are pulling in stock classes build some wieght brackets, Raise the drawbar to the legal limet and try it. Propane molines pull very well because of how they lug. If you want to bore and stroke it that gets expensive and won't always help you in a stock pull. I have watched large cube pulling tractors get beat by crusty old stock tractors in stock pulls. It seems like all the torque they have breaks loose easier and they spin out; at least on loose tracks.
