Moline governor
Tom H.
11-23-2002 18:31:09
I am restoring a 1952 utu that has a Pierce governor on it. Did this come with from the factory? And also, where can I get the setup specs for it? Thank you.
Kelvin
11-25-2002 17:35:14
 Re: moline governor in reply to Tom H., 11-23-2002 18:31:09
I'm pretty sure that pierce governors weren't original to '52 U's. The original was a flyweight type of MM's own design. When not totally worn out they do a pretty good job on a stock engine at stock rpm. (provided carburetion and ignition are up to snuff.)
If it fits in the hole in the side of the engine, probably you want to look at specs for something like a M5, M602, M670. I've seen at least one post wanting the adapter to fit a late (probably a pierce) governor into a 'pulling tractor.'
tom h
11-25-2002 19:29:19
 Re: Re: moline governor in reply to Kelvin, 11-25-2002 17:35:14
Yes, thank you for replying. I believe that mm used what they had left over from day to day and also from maybe from year to year I don't really know. This was one of the last years that they made the U. I guess that it might be interesting to find out what this is.
