Older Pull-Type 2-Bottom MM Plows
JKC
11-18-2002 16:42:16
Does anyone know how to go about estimating the year of a 2-bottom MM pull-type, trip-lift plow? I know it was sold as "used equipment" in 1953, but would like to estimate a year of manufacture for it..... don't believe the numbers on the plow will help me with that, or will they? Any suggestions would be greatly appreciated. Thanks.
Walt in Jaxn Tn.
11-18-2002 19:38:48
 Re: Older Pull-Type 2-Bottom MM Plows in reply to JKC, 11-18-2002 16:42:16
Don't know if this helps but, I have two MM plows almost identical both same size same # of bottoms except one is trip lift and the other is hydraulic lift. trip plows were made into the 1960s by some equipment mfgs.
Jeff Oliver
11-20-2002 20:44:17
 Re: Re: Older Pull-Type 2-Bottom MM Plows in reply to Walt in Jaxn Tn., 11-18-2002 19:38:48
Walt, your in Jackson Tn.? I am right up the road in Dresden. You go to the Atwood show or were you at the Fairgrounds this year for the fair? Get in touch !!!!
lance
11-19-2002 14:35:29
leave some part numbers on here and i will see if i can find out what model it is
