Odd vibration on 585D
Turbine Dude
11-15-2002 16:43:14
I ran across a MM the other day with a 585 in it ran it liked it and gave the owner an offer but.. The engine has right around 1000 hours since a full rebuild out of frame. And the engine runs great ect ect but as you stand on the tractor and run the rpms up from idle right around 2100rpm to 2250 rpm it seems to have an odd vibration. Not a teeth shakeing vibration but slightly noticble one. I have runn other 585's and they have there vibrations but this one seemed more pronounced. I have full confidence in the rebuild of the engine and it wouldn't have run this long if it had a problem. Now is this normal or not ? Could the harmonic balancer be bad??? Anyhelp would be greatly appreciated thanks T-D
