New MM owner needs help.
Kevin
10-28-2002 07:00:25
I have just bought an RTE.The serial no. on the side of the engine is 0175000750.The no. on the side of the trans case is unreadable.Could anyone give me an idea what year this tractor could be?Also,I need help finding a carb kit and a wiring harness or some info on wiring.It needs work but I love my little Minnie MO.Thank You.
BMG
10-28-2002 15:35:03
 Re: New MM owner needs help. in reply to Kevin, 10-28-2002 07:00:25
Congrats Kevin on getting yourself a nice 1950 RTE. I've got a 1950 RTE serial 004500173 with engine serial 0175001377. If you can read the last 3 numbers on your tag that's all you'll need since there were only 204 made in 1950. I've heard of guys removing the tag to look at the impressions on the back side of the tag but have never tried this myself. If you can make out any of the #s we might be able to fill in the blanks.
I used a Motec wire harness on my RTE. Well worth the $50 in saved wiring headaches alone. Call Matt at Motec (765-963-6628). Matt can probably help you with a carb kit also. He'll rebuild yours for $40 if you'd like. Good Luck!
Brian
Kevin
10-28-2002 17:29:51
 Re: Re: New MM owner needs help. in reply to BMG, 10-28-2002 15:35:03
Thank you for the help! I'll probably be a regular on this board asking for advice. Again, thanks to everyone for the information!
Kevin
Jim Parisot
10-28-2002 14:03:01
Kevin,
Nice find on a pretty desireable tractor. Your engine serial number indicates your tractor is a 1950 model year, one of 204 RTE's made that year. It was probably in the first half of that production. You'll have a lot of fun with it.
Jim
John
10-28-2002 11:51:16
NAPA has kits for these carbs, the NAPA, Echlin # is 2-1401. Motec has wiring harnesses for $50.00, they are listed under parts suppliers @ wwwMinneaplis-Moline.com
