Radiator cap for 1950 RTU
Dick Calland
10-15-2002 13:04:55
The cap that came with my RTU fits ok but appears to be a newer automotive type although the brand and part number are unknown to me. My repro parts manual shows radiator cap to be part number JT9031. The illustration does not look like what I have. My question is where can I get (whatever is) the proper radiator cap?
Jim Parisot
10-18-2002 08:34:39
 Re: radiator cap for 1950 RTU in reply to Dick Calland, 10-15-2002 13:04:55
Dick, the radiator cap is the easy one to find, it's the gas cap that is made of "unobtanium". The radiator cap is still being produced by Eaton, when I lost the fuel cap to my NH 1114 Windrower the new one they got me was identical to these old M-M radiator caps. You can find them on 60's and 70's Gleaner combine fuel tanks. The M-M parts suppliers still have them and I wouldn't doubt that an Agco dealer couldn't get one for you. The cooling system on old R's was not pressurized. Hope this helps.
Jim
Duke Mills
10-16-2002 19:52:02
I have a 1948 RTU and the repair manual indicates the part number to be the same as yours. My cap appears to be the original. It has no markings and looks just like the one in the manual. It appears to have a vent hole in the top center. It has no ears for tightening and looks like the old style chrome gas caps with vertical indentations to help grab and twist. The radiator cap is designed to lift at 6lbs pressure. So any cap that fits and lifts at 6lbs will work. By the way, do you know what the horsepower is for the engine is? Model 3 5/8 X 4 4 CYL E.E.
Jack
10-17-2002 20:13:17
 Re: Re: radiator cap for 1950 RTU in reply to Duke Mills, 10-16-2002 19:52:02
Your R should have around 27 belt HP and 23 on the drawbar. Jack
