Clutch plate clearence
Mike
02-10-2001 11:29:43
What is the correct clearence between the clutch plate and the pressure plate on my TE20?, ( fitting a new clutch plate)
Andre
02-12-2001 08:37:59
 Re: Clutch plate clearence in reply to Mike , 02-10-2001 11:29:43
Mike, I do not understand your question completely, but here is some info that may help:
Diameter Tractors TE-A20, TE-D20, TE-H20 9" 228.6mm. Tractor TE-F20 10" 254mm.
Clutch springs: Petrol 80mm bore: 9 orange (48648) 90-100lb each
Petrol 85mm bore: 9 Green(825534M1)105 - 115lb
Diesel: 12 green (825534M1) 105 - 115lb each
Max difference permitted in height of release fingers is 0.015" (0.39mm)
Free movement of pedal should be 3/8" (9.5mm). This is taken between the upper side of the pedal and underside of footrest bracket. Movement of release lever ends 1/2" (13mm). Variation in release lever hight should not exeed 0.015" (381mm).
Run-out of flywheel contact face at the outer dia. should not exeed 0.003" (0.08mm).
I hope that this solves your problem, enjoy your Massy!!
