Knocking/banging
lefler
01-31-2001 10:22:35
hi, i have a severe bang or pop which is coming from under the battery area
in my massey ferguson to35.here is what i've suspected and done:
1:#1 plug was fouled, replaced.
2: when i disconnect #1 plug noise quits
3: replaced connecting rod bearings(4)crankshaft was in good condition.
4: checked pistons, looked fine to a novice, but #1 seemed a tad loose.
5: replaced breaker points, timed engine.
6: replaced timing gearcover gasket along with front oil seal, no play in crank, the noise is still there, i tried to isolate it with a long srewdriver
to my ear and engine.the noise appear to be more of a air/exhuast noise,
but is not coming from the exhuast pipe. my suspests are:
1: bad #1 piston, hope not.
2: bad timing.
3: bad valves.
4: some type of exhuast vavle or venting.
5: air cleaner troubles
please if anyone can help.thank you
lefler
01-31-2001 15:42:23
 Re: knocking/banging in reply to lefler, 01-31-2001 10:22:35
TO-35
was home today messing with the tractor, while the engine was running and popping from under the battery area, not exhaust pipe, i,d pull the choke out slowly the noise would stop. Ray thinks an intake problem, i'm leaning that way myself. any other suggestions? thank,...tom
Ray,IN
02-04-2001 18:19:41
 Re: Re: knocking/banging in reply to lefler, 01-31-2001 15:42:23
That was intake valve problem!
Greg McKinney
02-03-2001 12:16:10
I don't have much experience with the 35/135s, but your problem could be something as simple as a set of spark plug wires. I've seen a bad plug wire stump more than one good mechanic. I would suggest replacing the plug wires and if that doesn't fix it, I'd replace the distributor cap and rotor before I started taking manifolds off the engine. I've had a bad plug wire give me and my dad hair on an old green tractor. It will do pretty much the same thing you're describing. It's a much cheaper fix than replacing manifolds, and if it doesn't fix your problem, at least you still got new ignition parts.
Good luck.
