Gas gauge or sender
Nogrimace
01-31-2001 10:07:05
I have no reading for my fuel. I do have power going to the sender, how do I check to see which is bad, the gauge or the sender????? If someone knows I would apppreciate it. It is a MF-40 wannabe backhoe, runs on diesel. thanks
MF
02-02-2001 07:18:45
 Re: Gas gauge or sender in reply to Nogrimace, 01-31-2001 10:07:05
Take the wire off the sending unit. Run a jumper wire to a ground AWAY from the tank. Momentarily touch the wires together, watch the gauge. If the gauge is ok you should get the needle to move all the way over. To test the sending unit, take it out of the tank(reconnect wire) and move the float back and forth through its range of travel, check gauge.
