MF1100 value
Geoff
01-30-2001 21:59:51
I'm looking at an 1100 used for last 2 decades as a hay loading tractor. Dealer bought it, fixed tranny (apparently fouled up) and looked at bearings (ok?). This 3pt is also jammed up. Dual speed PTO, diesel, 2 remotes, extra set of rears, new paint. No loader. Asking $7000. High???
RDS
02-04-2001 12:13:43
 Re: MF1100 value in reply to Geoff, 01-30-2001 21:59:51
I paid $4500.00 for my 1100. The 3 point was stuck but I fixed that myself. Came with a loader and grapple. Runs good and plenty of power but I would not have paid any more for it.
Pappy(KY)
02-02-2001 07:25:41
That does seem a bit high, I've got a MF 2805 with cab and duals that I'm only asking 4500 for, and it too has an inop lift(weak main hydraulic pump). Think I would keep looking. Good Luck with it.
Ron
02-05-2001 19:32:20
 Re: Re: MF1100 value in reply to Pappy(KY), 02-02-2001 07:25:41
What is the sn of the 2805 and is it 24speed or 8speed. How many hours on it.
Sent you an email-Pappy(Ky)
02-06-2001 06:26:45
 Re: Re: Re: MF1100 value in reply to Ron, 02-05-2001 19:32:20
x
David
02-01-2001 17:59:51
$7000.00 is too high. Especially if there are lift problems. That tractor should go in the 4 to 5 thousand range. Don't get me wrong, the 1100 is a very good tractor. I own one myself. You have to discount for mechanical problems (3pt repairs can get expensive)Plus $7000 is only the asking price, good luck. David
Bob
02-01-2001 14:02:13
The 1100 is a good tractor. In Ohio an 1100 goes for between $4500.00 and $7500.00. For $7000.00 I would think everything should work. I would make the dealer fix the 3pt.
