Chip
01-30-2001 10:47:30
Re: My MF35 won't start.. -Any ideas anyone?? in reply to Runar Hollerud, 01-30-2001 08:45:36
You should not be opening the fuel injection pump, my perkins can be a little difficult to bleed out, start at the primary fuel filter, open the vent and pump the lift pump until you get fuel without air bubbles, close the vent. Then open vent on the secondary filter, and do the same thing. Now move over to the injection pump, you will find a high vent that should look like a small bolt with a jam nut under it, loosen this and pump the lift pump until you get air free fuel, then tighten. Now loosen the high pressure fuel connection at the number one (front) fuel injector, push in the fuel rod, and crank until you get fuel there. Now tighten the high pressure line, and crank it again, it should start, it might be a little rough at first, but the other injectors will purge themselves readily. Be patient, sometimes it seems like forever when you're pumping that lift pump. (Of course if the lift pump isn't working, you're going to have a bit of a problem with this) Good luck Chip
