Timing chain replacement???
Vroei
01-29-2001 03:25:26
First of all: Guys thanks for the help with the electrical system on my MF-35. I replaced the solenoid and put a new battery in to find out that I had to take the starter appart for a clean-up of the brushes. It is now starting up fine again.
From the knowledge I haven on normal car gas-engines you have to replace the timing chain sometimes to prevent breakage and engine disasters. Is this also required for the Standard Engines on the MF-35's??? And if so how often and what would it take to do so?
Jack in NB
01-29-2001 06:41:21
 Re: Timing chain replacement??? in reply to Vroei, 01-29-2001 03:25:26
Hello Vroei -
Haven't heard of timing chain problems on this engine - probably because of the rugged design compared with later car engines. (read - how many car engines will still be running 45 years after production?!)
We did have a problem with the tensioner assembly on ours - flopped apart and dropped to the bottom of the cover at some point before the last overhaul. Engine continued to run for an unknown number of hours, with no damage to chain or gear teeth.
The tensioner assembly was not available in NA - we rebuilt it with brazing and grinding.
To answer your question - chain breakage doesn't seem to be an issue, in my opinion. I would not strip the tractor just to check it. But - if you have an opportunity to get at the unit when completing other repairs, by all means take a look!
