try and get a later one (exhaust on rightside of the bonnet)..... .which is the perkins 212 motor have a test drive first! -check for slop in the steering (common problem in heavy loader work) -if multipower check to see if it engages properly into high (should be a lurch when shifting) -look for basic leaks....common problem is leaking oil out of the back seal in the engine....i think -find out if you have a later one or an earlier one (makes a lot easier for matching parts if required - the early ones had an oil bath air filter (later 212 motor had the screw in paper element type early one had the engine oil filter on the right.....it was not a screw in type (its a filter that sits in a bowl)....later ones were the screw on type on the left of the motor both motors had two fuel filters and the same injector set up, but the 203 had one filter on the left and one filter on the right of the motor....the 212 had both on the right - if specified some 165 had the auxilary oil filter on the left side of the motor for the backend external huydralics.....some had a oil cooler in front of the radiator, by the air cleaner..... some tractors had nothing at all.....if ya had a choice get the tractor with the auxilary oil filter..... might be handy in the future both models of 165 have a wash able backend oilfilter in the housing under the seat..... .to get at the early model one, you drop the backend oil and remove the plate under the transmission with 3 bolts in it and you should see it on the later model you access the filter by removing the PTO lever (by the left hand foot plate) both models have elypictal hubs resivours in the back end under both mudgaurds..... these are often neglected.....the require 2 pints? (075litres??) of sae80 oil in them -the early one (the 203 motor), had dry brake.....(squek when applied)....the later model ones were wet.....heaps better -weighed about 2 tonnes (metric), and lifted about 1.3 tonnes on the backend hope this is understandable and i haven't confused pudding
