MF65
David F.
01-24-2001 17:29:20
Can anyone tell me the availability of parts for MF tractors; Mf 65 gas???
Pat
01-25-2001 06:05:33
 Re: MF65 in reply to David F., 01-24-2001 17:29:20
Parts for a MF65 are still relatively easy to find, at least compared to much older models. Many parts are available from dealers (can be very expensive). Pumps, etc. can often be obtained from other manufacturers or as rebuilt (still not that cheap, but better), and most tractor wreckers will have at least a few MF65 they are dismantling (cheaper, but still not in the cheapskate range). Some parts for the 165 are interchangable with the 65.
Larry
01-25-2001 14:22:54
 Re: Re: MF65 in reply to Pat, 01-25-2001 06:05:33
Just finished restoring one .What kind of parts do you need?
Michael Popp
02-20-2001 11:04:18
 Re: Re: Re: MF65 in reply to Larry, 01-25-2001 14:22:54
I currently have a 1963 MF 65. The sheet metal hood is missing the air cleaner assembly located on the front end of the hood. Also need the front sheet metal panel located below the right and left doors on the front. Any ideas where I can locate one in a salvage yard. So far I have had no luck.
I will be restoring this tractor this year. Any help would be appreciated. Thanks
Michael Popp
