BlueLight
01-21-2001 17:19:09
Re: Massey Harris 30-GR in reply to MT, 01-21-2001 08:10:22
The MFG date you can get on the trans housing just below the clutch pedal, its cast in date. The numbers I don't know. Try tractor registry this board. For parts depends where you live, but in general clutch,points,filter,carb kits,brake shoes w/brass rivets from MF. Carb kits also from ford. Things that you baby and hang onto for dear life carb,rims,dist cap,rad,governor,front wheel bearings. The rims are the worst to find, if there's calcium in your tires, chances are the rims are paper thin, very dangerous. The Continental engine is common and anyone can do a rebuild. If they say you can't get parts, it's BS, find another guy. The front rims you can use chrysler, cept you'll have to ream out the hub hole a little. You can build an air cleaner out of an old V8 air breather and tuck the whole thing under the tin, and replace existing oil filter can with a cartridge type oil filter that fits a 302 ford engine. Just make it out of steel plate brass fittings and copper tubes. Cheaper too has the MH filter is about 16.00 canadian. If you can find another that's scrapped, the transmission alone can take you out of a bad fix one day, so buy it. If the engine is seized, give the guy less. Plus you'll have 2 of everything, important when the manufacturer is no longer alive. The water pump,front wheel hubs and the external routing of the oil lines differ from the 49 to the 51. But that's no big deal. Hydraulic 3PH cylinders for the MH are worth their weight in gold, if you find one complete with handle with the chrome in good shape, hang onto it. Hope that helps. Blue
